Aller au contenu principal
Blackberry Bold 9900 Power/Volume Button Replacement
Ce dont vous avez besoin
  1. Blackberry Bold 9900 Power/Volume Button Replacement, Battery: étape 1, image 1 de 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Power/Volume Button Replacement: étape 2, image 1 de 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Power/Volume Button Replacement, Mini-SIM removal: étape 3, image 1 de 1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
  4. Blackberry Bold 9900 Power/Volume Button Replacement, MicroSD card: étape 4, image 1 de 2 Blackberry Bold 9900 Power/Volume Button Replacement, MicroSD card: étape 4, image 2 de 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  5. Blackberry Bold 9900 Power/Volume Button Replacement, Keyboard: étape 5, image 1 de 2 Blackberry Bold 9900 Power/Volume Button Replacement, Keyboard: étape 5, image 2 de 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  6. Blackberry Bold 9900 Power/Volume Button Replacement: étape 6, image 1 de 2 Blackberry Bold 9900 Power/Volume Button Replacement: étape 6, image 2 de 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  7. Blackberry Bold 9900 Power/Volume Button Replacement: étape 7, image 1 de 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  8. Blackberry Bold 9900 Power/Volume Button Replacement: étape 8, image 1 de 2 Blackberry Bold 9900 Power/Volume Button Replacement: étape 8, image 2 de 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  9. Blackberry Bold 9900 Power/Volume Button Replacement, Back Case: étape 9, image 1 de 1
    • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
  10. Blackberry Bold 9900 Power/Volume Button Replacement: étape 10, image 1 de 1
    • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
  11. Blackberry Bold 9900 Power/Volume Button Replacement, Power/Volume Button: étape 11, image 1 de 3 Blackberry Bold 9900 Power/Volume Button Replacement, Power/Volume Button: étape 11, image 2 de 3 Blackberry Bold 9900 Power/Volume Button Replacement, Power/Volume Button: étape 11, image 3 de 3
    • Use the black nylon spudger to pop the press fit connector up from the lower left corner of the motherboard.
  12. Blackberry Bold 9900 Power/Volume Button Replacement: étape 12, image 1 de 1
    • Lift the midframe, which contains the power/volume buttons, off of the motherboard and screen.
Sarah Westberg
Membre depuis le 03/11/19
23 019 Réputation
70 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 722 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 1,149
