Aller au contenu principal
Blackberry Curve 9300 Speaker Replacement
Ce dont vous avez besoin
  1. Blackberry Curve 9300 Speaker Replacement, Battery: étape 1, image 1 de 1
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Speaker Replacement: étape 2, image 1 de 1
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Speaker Replacement: étape 3, image 1 de 1
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Speaker Replacement, Keyboard: étape 4, image 1 de 1
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Speaker Replacement: étape 5, image 1 de 2 Blackberry Curve 9300 Speaker Replacement: étape 5, image 2 de 2
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Speaker Replacement: étape 6, image 1 de 1
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Speaker Replacement: étape 7, image 1 de 1
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Speaker Replacement: étape 8, image 1 de 1
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Speaker Replacement: étape 9, image 1 de 1
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Speaker Replacement, Speaker: étape 10, image 1 de 1
    • Locate and remove the two 5mm screws on top of the keyboard base with a T6 Torx screwdriver.
  11. Blackberry Curve 9300 Speaker Replacement: étape 11, image 1 de 1
    • Carefully pull keyboard base up and away from phone.
    • Disconnect keyboard base from phone completely.
  12. Blackberry Curve 9300 Speaker Replacement: étape 12, image 1 de 3 Blackberry Curve 9300 Speaker Replacement: étape 12, image 2 de 3 Blackberry Curve 9300 Speaker Replacement: étape 12, image 3 de 3
    • Remove the four 5mm screws on the top and bottom of phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Speaker Replacement: étape 13, image 1 de 2 Blackberry Curve 9300 Speaker Replacement: étape 13, image 2 de 2
    • Using a prying tool, find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • Prying tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Speaker Replacement: étape 14, image 1 de 2 Blackberry Curve 9300 Speaker Replacement: étape 14, image 2 de 2
    • From the back of the phone, use your finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Speaker Replacement: étape 15, image 1 de 1
    • Insert tweezers into the small holes on the top of the speaker.
  16. Blackberry Curve 9300 Speaker Replacement: étape 16, image 1 de 2 Blackberry Curve 9300 Speaker Replacement: étape 16, image 2 de 2
    • Lift the speaker up to remove the speaker from phone.
6 autres ont terminé cette réparation.
Alek Squires
Membre depuis le 09/30/13
431 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-7, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 14-7, Forte Fall 2013
CPSU-FORTE-F13S14G7
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 4,134
