Aller au contenu principal
Blackberry Torch 9800 Logic Board Replacement
Ce dont vous avez besoin
  1. Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: étape 1, image 1 de 2 Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: étape 1, image 2 de 2
    • Remove the back cover and the battery.
    • Unscrew the four screws using a T6 screwdriver.
    • Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Logic Board Replacement: étape 2, image 1 de 2 Blackberry Torch 9800 Logic Board Replacement: étape 2, image 2 de 2
    • Remove the side trim using the plastic opening tool.
    • Apply pressure to push the top side of the side trim towards the phone while pulling the bottom away from the phone to remove the side trim.
    • The side trim is fragile and easily fractured, so handful it with care.
  3. Blackberry Torch 9800 Logic Board Replacement: étape 3, image 1 de 3 Blackberry Torch 9800 Logic Board Replacement: étape 3, image 2 de 3 Blackberry Torch 9800 Logic Board Replacement: étape 3, image 3 de 3
    • Remove the two screws that have been revealed at the top of the device using the T6 screwdriver.
    • You should now be able to easily lift the back panel from the phone.
  4. Blackberry Torch 9800 Logic Board Replacement: étape 4, image 1 de 2 Blackberry Torch 9800 Logic Board Replacement: étape 4, image 2 de 2
    • Using your hands, carefully peel the three ribbon cable caps from the logic board.
  5. Blackberry Torch 9800 Logic Board Replacement: étape 5, image 1 de 2 Blackberry Torch 9800 Logic Board Replacement: étape 5, image 2 de 2
    • Lift logic board slightly. The logic board will remain attached to the phone by a small antenna wire.
    • Using your hands, carefully lift the clasp attached to the antenna wire straight upward away from the logic board.
    • Make sure not to disconnect the antenna wire from its clasp.
    • The logic board should now be completely separate from the phone.
3 autres ont terminé cette réparation.
Keegan Williams
Membre depuis le 02/19/16
216 Réputation
2 tutoriels rédigés
Équipe
Ohio State, Team 1-5, Garvin Spring 2016 Membre de l'équipe Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 861
