Aller au contenu principal
Blackstone Cascade Pro Fan Replacement
Ce dont vous avez besoin
  1. Blackstone Cascade Pro Fan Replacement, Fan: étape 1, image 1 de 3 Blackstone Cascade Pro Fan Replacement, Fan: étape 1, image 2 de 3 Blackstone Cascade Pro Fan Replacement, Fan: étape 1, image 3 de 3
    • Remove the four screws surrounding the back of the Blackstone fan using a Phillips #00 screwdriver.
    • Remove the cover at the back of the fan.
  2. Blackstone Cascade Pro Fan Replacement: étape 2, image 1 de 2 Blackstone Cascade Pro Fan Replacement: étape 2, image 2 de 2
    • Remove the diamond cover at the top of the fan.
    • The diamond cover will be connected to a set of wires to the fan. Simply place the cover to the side for the rest of the repair.
  3. Blackstone Cascade Pro Fan Replacement: étape 3, image 1 de 3 Blackstone Cascade Pro Fan Replacement: étape 3, image 2 de 3 Blackstone Cascade Pro Fan Replacement: étape 3, image 3 de 3
    • Remove the two screws that are holding the spherical cover shielding the main fan using a Phillips #00 screwdriver.
    • Remove the spherical cover surrounding the main fan.
  4. Blackstone Cascade Pro Fan Replacement: étape 4, image 1 de 2 Blackstone Cascade Pro Fan Replacement: étape 4, image 2 de 2
    • On the opposite side there will be a cover identical to the one removed in the previous step.
    • Twist the main fan to remove the cover on the opposite side.
  5. Blackstone Cascade Pro Fan Replacement: étape 5, image 1 de 3 Blackstone Cascade Pro Fan Replacement: étape 5, image 2 de 3 Blackstone Cascade Pro Fan Replacement: étape 5, image 3 de 3
    • Using the socket wrench, and a size 10 shallow socket, remove the hexagon screw at the center of the main fan.
    • Pull out the main fan.
    • Depending on the age of your fan, it may require more strength to pull it out. Be careful to not use too much force.
2 autres ont terminé cette réparation.
Mohamed Mallah
Membre depuis le 01/24/24
148 Réputation
1 tutoriel rédigé
Équipe
York University, Team P-1, O'Regan Winter 2024 Membre de l'équipe York University, Team P-1, O'Regan Winter 2024
YORK-O'REGAN-W24SPG1
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 296
