Aller au contenu principal
Blu Dash 5.0 Dual SIM Back Camera Replacement
Ce dont vous avez besoin
  1. Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: étape 1, image 1 de 2 Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: étape 1, image 2 de 2
    • Make sure device is disconnected and turned off.
    • Locate the groove on the bottom left corner of the back of the phone.
    • Insert the plastic opening tool into the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Back Camera Replacement: étape 2, image 1 de 1
    • Pry the battery out using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Back Camera Replacement: étape 3, image 1 de 1
    • Remove the 12 screws on the back panel using a J000 screwdriver.
    • Red circles correspond to the screw holes holding 3.5 mm length Phillips screws.
    • Orange circles correspond to the screw holes holding 2.5 mm length Phillips screws.
  4. Blu Dash 5.0 Dual SIM Back Camera Replacement: étape 4, image 1 de 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: étape 4, image 2 de 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: étape 4, image 3 de 3
    • Peel off the back panel with your hand.
    • Remove the back panel slowly to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Back Camera Replacement: étape 5, image 1 de 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: étape 5, image 2 de 3 Blu Dash 5.0 Dual SIM Back Camera Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Flip up the ZIF flap using the spudger.
    • Gently remove the ribbon cable with tweezers.
    • The ribbon cable is sensitve and needs to be removed carefully to insure its integrity.
    • Remove the back camera using tweezers.
Mukish Kumar Munyady
Membre depuis le 01/30/17
201 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Baechle Spring 2017 Membre de l'équipe IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 378
