Aller au contenu principal
Introduction
The camera may need to be replaced if you are taking pictures and the pictures turn our black or you are receiving an error message when accessing the camera. Be aware that there may be glue under some components.
  1. Remove the two plastic plates with a plastic opening tool. Remove the two plastic plates with a plastic opening tool.
    • Remove the two plastic plates with a plastic opening tool.
  2. Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Remove SIM card tray with paperclip or SIM card tray removal tool. Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate.  Remove adhesive if necessary. Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate.  Remove adhesive if necessary.
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  5. There is a patch of adhesive underneath the battery, which can make it difficult to remove. Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  6. Remove the yellow plastic tape using a pair of tweezers. Remove the yellow plastic tape using a pair of tweezers.
    • Remove the yellow plastic tape using a pair of tweezers.
  7. Use a Phillips #000 screwdriver to remove two black 4.0mm screws. Use a Phillips #000 screwdriver to remove 2 silver 4.0mm screws Remove the plastic cover along the top by tugging on it on the corner as shown.
    • Use a Phillips #000 screwdriver to remove two black 4.0mm screws.
    • Use a Phillips #000 screwdriver to remove 2 silver 4.0mm screws
    • Remove the plastic cover along the top by tugging on it on the corner as shown.
  8. Use the plastic opening tool to lift the camera out. Use the plastic opening tool to lift the camera out.
    • Use the plastic opening tool to lift the camera out.
Cameron Retzlaff
Membre depuis le 17/09/2018
608 Réputation
5 tutoriels rédigés
Équipe
Washington State, Team S9-G2, Hope Fall 2018 Membre de l'équipe Washington State, Team S9-G2, Hope Fall 2018
WSU-HOPE-F18S9G2
3 membres
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 42
