Aller au contenu principal
Blu Grand M Vibrator Replacement
Ce dont vous avez besoin
  1. Blu Grand M Vibrator Replacement, Battery: étape 1, image 1 de 2 Blu Grand M Vibrator Replacement, Battery: étape 1, image 2 de 2
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Vibrator Replacement: étape 2, image 1 de 1
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Vibrator Replacement: étape 3, image 1 de 3 Blu Grand M Vibrator Replacement: étape 3, image 2 de 3 Blu Grand M Vibrator Replacement: étape 3, image 3 de 3
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Vibrator Replacement: étape 4, image 1 de 2 Blu Grand M Vibrator Replacement: étape 4, image 2 de 2
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Vibrator Replacement, Speaker: étape 5, image 1 de 2 Blu Grand M Vibrator Replacement, Speaker: étape 5, image 2 de 2
    • Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
    • Remove the 4.0mm screw with a Phillips #000 screwdriver.
    • Using the blue plastic opening tool, remove the exterior cover.
  6. Blu Grand M Vibrator Replacement: étape 6, image 1 de 3 Blu Grand M Vibrator Replacement: étape 6, image 2 de 3 Blu Grand M Vibrator Replacement: étape 6, image 3 de 3
    • Use a Phillips #000 screwdriver to remove each of the four 1.5mm screws.
    • Use a Phillips #000 screwdriver to remove each of the three 3.0mm screws.
    • Use the plastic opening tool to remove the speaker.
  7. Blu Grand M Vibrator Replacement, Microphone: étape 7, image 1 de 2 Blu Grand M Vibrator Replacement, Microphone: étape 7, image 2 de 2
    • Disconnect the black wire with a pair of tweezers.
    • The black wire can swivel out of the way to easily access the next microphone.
  8. Blu Grand M Vibrator Replacement: étape 8, image 1 de 2 Blu Grand M Vibrator Replacement: étape 8, image 2 de 2
    • Use a pair of tweezers to remove the orange data cable as shown.
  9. Blu Grand M Vibrator Replacement: étape 9, image 1 de 3 Blu Grand M Vibrator Replacement: étape 9, image 2 de 3 Blu Grand M Vibrator Replacement: étape 9, image 3 de 3
    • There will be glue holding the wires down, and they can be glued back in place after.
    • Use the plastic opening tool to lift the microphone out of place.
    • Use a pair of tweezers to lift the microphone out of the phone.
  10. Blu Grand M Vibrator Replacement, Vibrator: étape 10, image 1 de 2 Blu Grand M Vibrator Replacement, Vibrator: étape 10, image 2 de 2
    • To remove the vibrator, use the plastic opening tool to pry it out.
Cameron Retzlaff
Membre depuis le 09/17/18
608 Réputation
5 tutoriels rédigés
Équipe
Washington State, Team S9-G2, Hope Fall 2018 Membre de l'équipe Washington State, Team S9-G2, Hope Fall 2018
WSU-HOPE-F18S9G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 126
