Aller au contenu principal
Blu Grand M2  Power Button Replacement
Alan Rodriguez
Alan Rodriguez et 9 autres contributeurs
Dernière mise à jour le January 25, 2022
1 - 3 minutes
Facile
A besoin de meilleures images
If your BLU Grand M2 phone is not responding when you are pressing the power button, you may need a power button replacement. This guide has been made to help you install your power button on your own. It will show you how to remove the screws, remove the back panel, and detach the power button.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Blu Grand M2  Power Button Replacement, Power Button: étape 1, image 1 de 1
    • Using a T2 Torx Screwdriver, remove the two screws from the bottom edge of the phone.
  2. Blu Grand M2  Power Button Replacement: étape 2, image 1 de 2 Blu Grand M2  Power Button Replacement: étape 2, image 2 de 2
    • Apply the suction tool to the back panel near the bottom edge.
    • Carefully slide the device pick between the back panel and bottom edge.
    • Insert the opening tool into the gap created by the device pick.
    • While holding the suction tool, use the opening tool to gently pry the back panel off.
    • Be Cautious to not damage the phone display and or the inside components while using the pry tool and suction tool.
  3. Blu Grand M2  Power Button Replacement: étape 3, image 1 de 1
    • Take the end of the opening tool and push the old power button out of its socket.
    • Remove the old power button.
  4. Blu Grand M2  Power Button Replacement: étape 4, image 1 de 1
    • Place the new BLU Grand M2 power button in the socket.
Alan Rodriguez
Membre depuis le 09/10/18
311 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team S1-G3, Luster Fall 2018 Membre de l'équipe Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Don’t forget to remove the SIM card
Jonathan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 388
