Introduction
This guide was made to help you if you are experiencing a BLU GRAND M2 charging failure. This guide will help you replace the charging port for the BLU GRAND M2.
In order to follow this guide, you will need to solder. Check out the How to Solder and Desolder Connections guide before you start if you are unfamiliar or need a refresher. Also be sure to power off the phone before beginning your repair.
Ce dont vous avez besoin
Carefully pry the motherboard assembly from the phone.
The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
After installing the new port, repeat the steps in reverse order to reassemble the phone.
