Aller au contenu principal
Blu L120 Motherboard Replacement
Ce dont vous avez besoin
  1. Blu L120 Motherboard Replacement, Remove back panel: étape 1, image 1 de 3 Blu L120 Motherboard Replacement, Remove back panel: étape 1, image 2 de 3 Blu L120 Motherboard Replacement, Remove back panel: étape 1, image 3 de 3
    • Remove the cover by lifting the notch towards the bottom of the phone. Use your fingernail to lift it up.
  2. Blu L120 Motherboard Replacement, Screw Removal: étape 2, image 1 de 3 Blu L120 Motherboard Replacement, Screw Removal: étape 2, image 2 de 3 Blu L120 Motherboard Replacement, Screw Removal: étape 2, image 3 de 3
    • Remove these nine screws with a small phillips screwdriver. They are all the same size.
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it .
  3. Blu L120 Motherboard Replacement, Rear Panel  removal: étape 3, image 1 de 3 Blu L120 Motherboard Replacement, Rear Panel  removal: étape 3, image 2 de 3 Blu L120 Motherboard Replacement, Rear Panel  removal: étape 3, image 3 de 3
    • Use the pry tool to gently separate the panel from the frame, starting from the bottom left corner and continue along the edge of the phone.
    • *WARNING* by doing this, you will void the manufacturers warranty.
  4. Blu L120 Motherboard Replacement, Separate back panel from frame: étape 4, image 1 de 3 Blu L120 Motherboard Replacement, Separate back panel from frame: étape 4, image 2 de 3 Blu L120 Motherboard Replacement, Separate back panel from frame: étape 4, image 3 de 3
    • Continue using the pry tool around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Motherboard Replacement, Camera Removal: étape 5, image 1 de 3 Blu L120 Motherboard Replacement, Camera Removal: étape 5, image 2 de 3 Blu L120 Motherboard Replacement, Camera Removal: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use the pry tool to disconnect the camera from the device.
    • Gently lift the camera up and use the tweezers to remove it from the phone.
    • Reinstall the camera. Then follow the guide in reverse to put the phone back together.
  6. Blu L120 Motherboard Replacement, Motherboard: étape 6, image 1 de 3 Blu L120 Motherboard Replacement, Motherboard: étape 6, image 2 de 3 Blu L120 Motherboard Replacement, Motherboard: étape 6, image 3 de 3
    • Remove these three screws using 00 Philips screwdriver. Note the smaller screw circled in orange.
    • Then gently pry up on the metal antenna connector at the end of the grey wire. Move the wire out of the way.
  7. Blu L120 Motherboard Replacement: étape 7, image 1 de 2 Blu L120 Motherboard Replacement: étape 7, image 2 de 2
    • Next you must disconnect these three cables.
    • Use your pry tool to lift up on the brown tab to release the ribbon cable.
  8. Blu L120 Motherboard Replacement: étape 8, image 1 de 3 Blu L120 Motherboard Replacement: étape 8, image 2 de 3 Blu L120 Motherboard Replacement: étape 8, image 3 de 3
    • For the last ribbon cable, use a spudger to gently pry up on the board under the right sim card slot.
    • Next, take your pry tool to lift up on the brown tab holding down the ribbon cable.
    • The cable is now free to be pulled back out of its' slot.
  9. Blu L120 Motherboard Replacement: étape 9, image 1 de 3 Blu L120 Motherboard Replacement: étape 9, image 2 de 3 Blu L120 Motherboard Replacement: étape 9, image 3 de 3
    J'achète
    • Using a spudger, peel up on the mesh tape then use your tweezers to peel the rest of it up.
  10. Blu L120 Motherboard Replacement: étape 10, image 1 de 3 Blu L120 Motherboard Replacement: étape 10, image 2 de 3 Blu L120 Motherboard Replacement: étape 10, image 3 de 3
    • Now that the motherboard is free to be pried up, be sure that no cables are in the way or can be snagged when removing the motherboard.
    • Just lift up and away.
    • Follow the instructions in reverse to put the phone back together.
Julio
Membre depuis le 10/25/14
695 Réputation
6 tutoriels rédigés
Équipe
Gateway, Team 1-5, Johnson Fall 2014 Membre de l'équipe Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 718
