Aller au contenu principal
Blu L120 Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. Blu L120 Rear Facing Camera Replacement, Remove back panel: étape 1, image 1 de 3 Blu L120 Rear Facing Camera Replacement, Remove back panel: étape 1, image 2 de 3 Blu L120 Rear Facing Camera Replacement, Remove back panel: étape 1, image 3 de 3
    • Remove the cover by lifting the notch towards the bottom of the phone. Use your fingernail to lift it up.
  2. Blu L120 Rear Facing Camera Replacement, Screw Removal: étape 2, image 1 de 3 Blu L120 Rear Facing Camera Replacement, Screw Removal: étape 2, image 2 de 3 Blu L120 Rear Facing Camera Replacement, Screw Removal: étape 2, image 3 de 3
    • Remove these nine screws with a small phillips screwdriver. They are all the same size.
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it .
  3. Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: étape 3, image 1 de 3 Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: étape 3, image 2 de 3 Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: étape 3, image 3 de 3
    • Use the pry tool to gently separate the panel from the frame, starting from the bottom left corner and continue along the edge of the phone.
    • *WARNING* by doing this, you will void the manufacturers warranty.
  4. Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: étape 4, image 1 de 3 Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: étape 4, image 2 de 3 Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: étape 4, image 3 de 3
    • Continue using the pry tool around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Rear Facing Camera Replacement, Camera Removal: étape 5, image 1 de 3 Blu L120 Rear Facing Camera Replacement, Camera Removal: étape 5, image 2 de 3 Blu L120 Rear Facing Camera Replacement, Camera Removal: étape 5, image 3 de 3
    • Use the pry tool to disconnect the camera from the device.
    • Gently lift the camera up and use the tweezers to remove it from the phone.
    • Reinstall the camera. Then follow the guide in reverse to put the phone back together.
Julio
Membre depuis le 10/25/14
695 Réputation
6 tutoriels rédigés
Équipe
Gateway, Team 1-5, Johnson Fall 2014 Membre de l'équipe Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 6
Total : 205
