Introduction
This guide will help you properly remove the back case of the phone. It is a simple and easy two step process.
In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
Ajouter un commentaire
Place your finger in the small notch on the left side of the charging port (facing from the back).
  • Place your finger in the small notch on the left side of the charging port (facing from the back).
  • Once your finger is in the notch, pull the back case towards yourself to remove it.
the phone i purchased does not have a notch that you described and the camera lens is in the middle and the flash is beneath
DAVID A WALKER - Réponse
it is impossible to open without damaging case (which I already did) . why don't these idiots provide a usable manual with their product? we aren't all mind readers
To reassemble your device, insert the two tabs located at the bottom of the cover into the indents at the bottom of the phone. Then, press down on all sides of the phone until you hear it snap into place.
Armen Garabedian
Membre depuis le 29/10/2014
156 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 4-8, Miles Fall 2014 Membre de l'équipe UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 781
