Aller au contenu principal
Blu Studio 5.5 S Back Case Replacement
  1. Blu Studio 5.5 S Back Case Replacement, Back Casing: étape 1, image 1 de 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Back Case Replacement, Applying Pressure: étape 2, image 1 de 3 Blu Studio 5.5 S Back Case Replacement, Applying Pressure: étape 2, image 2 de 3 Blu Studio 5.5 S Back Case Replacement, Applying Pressure: étape 2, image 3 de 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
To reassemble your device, insert the two tabs located at the bottom of the cover into the indents at the bottom of the phone. Then, press down on all sides of the phone until you hear it snap into place.
Armen Garabedian
Membre depuis le 10/29/14
162 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 4-8, Miles Fall 2014 Membre de l'équipe UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 1,009
