Aller au contenu principal
Blu Studio 5.5 S Screen Replacement
Ce dont vous avez besoin
  1. Blu Studio 5.5 S Screen Replacement, Back Casing: étape 1, image 1 de 1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Screen Replacement, Applying Pressure: étape 2, image 1 de 3 Blu Studio 5.5 S Screen Replacement, Applying Pressure: étape 2, image 2 de 3 Blu Studio 5.5 S Screen Replacement, Applying Pressure: étape 2, image 3 de 3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Screen Replacement, Battery: étape 3, image 1 de 3 Blu Studio 5.5 S Screen Replacement, Battery: étape 3, image 2 de 3 Blu Studio 5.5 S Screen Replacement, Battery: étape 3, image 3 de 3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Screen Replacement, Midframe: étape 4, image 1 de 3 Blu Studio 5.5 S Screen Replacement, Midframe: étape 4, image 2 de 3 Blu Studio 5.5 S Screen Replacement, Midframe: étape 4, image 3 de 3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Screen Replacement, Aesthetic Bottom Case: étape 5, image 1 de 1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Screen Replacement: étape 6, image 1 de 3 Blu Studio 5.5 S Screen Replacement: étape 6, image 2 de 3 Blu Studio 5.5 S Screen Replacement: étape 6, image 3 de 3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Screen Replacement, Motherboard: étape 7, image 1 de 3 Blu Studio 5.5 S Screen Replacement, Motherboard: étape 7, image 2 de 3 Blu Studio 5.5 S Screen Replacement, Motherboard: étape 7, image 3 de 3
    • Remove the three 7 mm screws using the Phillips #00 Screwdiver.
    • Disconnect motherboard plug connector near bottom right of battery using fingers to pull off the cap plug.
  8. Blu Studio 5.5 S Screen Replacement: étape 8, image 1 de 3 Blu Studio 5.5 S Screen Replacement: étape 8, image 2 de 3 Blu Studio 5.5 S Screen Replacement: étape 8, image 3 de 3
    • Use the nylon spudger to lift the release tabs by carefully grabbing the tabs from the sides and lifting up.
    • Release the four ribbon wires from the motherboard.
  9. Blu Studio 5.5 S Screen Replacement: étape 9, image 1 de 2 Blu Studio 5.5 S Screen Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use the tweezers to grip the bottom of the motherboard and lift up.
  10. Blu Studio 5.5 S Screen Replacement, Screen: étape 10, image 1 de 2 Blu Studio 5.5 S Screen Replacement, Screen: étape 10, image 2 de 2
    • Remove speaker circuit board from bottom of the phone by using a Spudger to gently lift up.
    • The speaker circuit board is attached with adhesive. Be careful not to break when removing.
    • Once this piece is removed, you can replace your part with the new screen and digitizer assembly.
Greg Cerabona
Membre depuis le 03/04/17
167 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G2, Wilson Spring 2017 Membre de l'équipe IUPUI, Team S2-G2, Wilson Spring 2017
IUPUI-WILSON-S17S2G2
5 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 11
Total : 987
