Aller au contenu principal
Blu Studio 5.5 Speakers Replacement
Ce dont vous avez besoin
  1. Blu Studio 5.5 Speakers Replacement, Battery: étape 1, image 1 de 3 Blu Studio 5.5 Speakers Replacement, Battery: étape 1, image 2 de 3 Blu Studio 5.5 Speakers Replacement, Battery: étape 1, image 3 de 3
    • Locate the notch to remove the back panel at the lower left corner of the panel.
    • Insert the plastic opening tool or a fingernail into the notch.
    • Apply force upwards until back panel becomes loosened.
  2. Blu Studio 5.5 Speakers Replacement: étape 2, image 1 de 2 Blu Studio 5.5 Speakers Replacement: étape 2, image 2 de 2
    • Remove the loosened back panel and set aside.
    • Locate the notch to remove the battery.
  3. Blu Studio 5.5 Speakers Replacement: étape 3, image 1 de 3 Blu Studio 5.5 Speakers Replacement: étape 3, image 2 de 3 Blu Studio 5.5 Speakers Replacement: étape 3, image 3 de 3
    • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
    • Remove the battery and set aside.
  4. Blu Studio 5.5 Speakers Replacement, Back Panel Assembly: étape 4, image 1 de 2 Blu Studio 5.5 Speakers Replacement, Back Panel Assembly: étape 4, image 2 de 2
    • Locate all twelve screws along the back panel:
    • Seven 5mm screws.
    • Five 3.5mm screws.
    • Using a Phillips #000 screwdriver, remove all twelve screws.
  5. Blu Studio 5.5 Speakers Replacement: étape 5, image 1 de 3 Blu Studio 5.5 Speakers Replacement: étape 5, image 2 de 3 Blu Studio 5.5 Speakers Replacement: étape 5, image 3 de 3
    • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
    • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
    • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
    • Remove the panel as if you were turning the page of a book.
  6. Blu Studio 5.5 Speakers Replacement, Speakers: étape 6, image 1 de 3 Blu Studio 5.5 Speakers Replacement, Speakers: étape 6, image 2 de 3 Blu Studio 5.5 Speakers Replacement, Speakers: étape 6, image 3 de 3
    • Using a pair of tweezers grasp the speakers that are located below the battery and pry it off as it is glued onto the phone assembly.
    • The speakers are connected by a pair of red and blue wires that are soldered onto the SUB PCBA component and will need to be soldered back on.
    • You can now remove the speakers and replace them.
    • It might be better to consider replacing the entire SUB-PCBA board instead of just the speakers individually to avoid dealing with the re-connection of the two wires.
Luis Gomez-Atehortua
Membre depuis le 02/28/17
452 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Nance Spring 2017 Membre de l'équipe USF Tampa, Team S1-G6, Nance Spring 2017
USFT-NANCE-S17S1G6
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 10
Total : 192
