Introduction
Before starting make sure you have your soldering workstation ready for use.
Begin by making sure your Blu Studio is turned off.
  • Begin by making sure your Blu Studio is turned off.
Ajouter un commentaire
To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
  • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
  • One of the lower right hand screws will be hidden under a sticker.
  • After removing all 16 screws you can begin the process of removing the battery housing panel.
  • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
  • Try to be careful around the side buttons as the plastic is weakest there.
  • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
  • The power button is located on the rear-left side of your phone just above the battery.
  • Lift the button very carefully.
  • Then unsolder the connections.
  • Solder the new power button in the spot shown in the picture.
  • Fit the button on the side of the phone.
4 autre(s) ont terminé cette réparation.
Ernesto Diaz
Membre depuis le 23/09/2014
1 718 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 9-1, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 membres
8 tutoriels rédigés
Where do you find a blu button?
senegalsoccerrules - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 24
Total : 3,936
