Aller au contenu principal
Blu Studio Selfie Battery Replacement
Ce dont vous avez besoin
  1. Blu Studio Selfie Battery Replacement, Rear Cover: étape 1, image 1 de 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Battery Replacement: étape 2, image 1 de 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Battery Replacement, Battery: étape 3, image 1 de 2 Blu Studio Selfie Battery Replacement, Battery: étape 3, image 2 de 2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
Stacy Kam
Membre depuis le 01/20/16
630 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 10-1, Remmell Spring 2016 Membre de l'équipe USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,345
