Introduction
If your phone is not responding when you are pressing the power button, you may need a power button replacement. This guide has been made to help you install your power button on your own. It will show you how to remove the screws, removing the back panel, and detach the power button.
Pièces
Aucune pièce nécessaire.
  1. Before beginning this guide, make sure this is the guide you have selected.
    • Before beginning this guide, make sure this is the guide you have selected.
    • After assuring the guide, locate the power button show in Figure 1.
  2. Begin by locating the torx screws and remove them show in (Figure 1).
    • Begin by locating the torx screws and remove them show in (Figure 1).
    • After removing the screws, begin by use the suction tool and pry tool, to slowly remove the black plate.
    • Be Cautious do not damage phone display and or inside components while using pry tool and suction tool.
    • Once the back panel is removed, locate the power button, remove it, and replace it with the new power button show in figure 1.
    • After you successfully replace the power button, repeat the steps in reverse order to reassemble the phone.
Alan Rodriguez
Membre depuis le 10/09/2018
279 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team S1-G3, Luster Fall 2018 Membre de l'équipe Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 membres
4 tutoriels rédigés
Don’t forget to remove the SIM card
Jonathan - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 28
Total : 39
