Aller au contenu principal
Blu Grand M2 Charging Port Assembly Replacement
Ce dont vous avez besoin
  1. Blu Grand M2 Charging Port Assembly Replacement, Charging Port Assembly: étape 1, image 1 de 1
    • Remove the screws with the T2 Torx screwdriver.
    • Place screws off to the side.
  2. Blu Grand M2 Charging Port Assembly Replacement: étape 2, image 1 de 2 Blu Grand M2 Charging Port Assembly Replacement: étape 2, image 2 de 2
    • Once the Torx screws have been removed, use a pry tool and a suction tool to remove the back plate.
    • Using the T2 Torx screwdriver, remove the six Torx screws on the motherboard.
    • Make sure to disconnect all other connections from the camera.
  3. Blu Grand M2 Charging Port Assembly Replacement: étape 3, image 1 de 1
    • Carefully pry the motherboard assembly from the phone.
    • The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
    • Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
    • After installing the new port, repeat the steps in reverse order to reassemble the phone.
    • How to Solder and Desolder Connections
Richard Hills
Membre depuis le 09/10/18
150 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G3, Luster Fall 2018 Membre de l'équipe Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 14
Total : 502
