Aller au contenu principal
Bolide Technology Group Dual Alarm Clock Speaker Replacement
Ce dont vous avez besoin
  1. Bolide Technology Group Dual Alarm Clock Speaker Replacement, Speaker: étape 1, image 1 de 3 Bolide Technology Group Dual Alarm Clock Speaker Replacement, Speaker: étape 1, image 2 de 3 Bolide Technology Group Dual Alarm Clock Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Slide the clear plastic case off of the speaker
  2. Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 2, image 1 de 3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 2, image 2 de 3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 2, image 3 de 3
    • Remove the batteries on the bottom of the radio
    • Locate and remove the five screws on the bottom of the radio with a Philips Head Screwdriver.
    • Make sure to keep your screws together so you don't lose them.
  3. Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 3, image 1 de 3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 3, image 2 de 3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 3, image 3 de 3
    • Grab your nylon pry tool and wedge it between the outer case and the top of the radio. Slowly pry open the top and remove it.
    • This may be more difficult to take off if the top hasn't been removed before, but it may be easier to turn the clock upside down for this step.
  4. Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 4, image 1 de 2 Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    Spudger
    $2.99
    J'achète
    • Using a black nylon spudger to carefully break the glue around the outside of the speaker so it can be dislodged.
  5. Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 5, image 1 de 3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 5, image 2 de 3 Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 5, image 3 de 3
    J'achète
    • Locate the speaker plug for the speaker you wish to remove and slightly tug on it until it becomes unplugged
    • This can also be done with a pair of tweezers if you find there isn't enough space.
  6. Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 6, image 1 de 2 Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 6, image 2 de 2
    • After the speaker cord is removed, pull the speaker straight up and out of the radio.
  7. Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 7, image 1 de 2 Bolide Technology Group Dual Alarm Clock Speaker Replacement: étape 7, image 2 de 2
    • Once the speaker is removed, the inside of the dual alarm clock should look identical to the photo shown.
Mercy Adeshola
Membre depuis le 02/20/17
121 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 10-1, Remmell Spring 2017 Membre de l'équipe USF Tampa, Team 10-1, Remmell Spring 2017
USFT-REMMELL-S17S10G1
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 15
Total : 698
