Aller au contenu principal
Boosted Board 1st Generation Rear Wheels Replacement
Ce dont vous avez besoin
  1. Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: étape 1, image 1 de 2 Boosted Board 1st Generation Rear Wheels Replacement, Rear Wheels: étape 1, image 2 de 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Rear Wheels Replacement: étape 2, image 1 de 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Rear Wheels Replacement: étape 3, image 1 de 2 Boosted Board 1st Generation Rear Wheels Replacement: étape 3, image 2 de 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Rear Wheels Replacement: étape 4, image 1 de 3 Boosted Board 1st Generation Rear Wheels Replacement: étape 4, image 2 de 3 Boosted Board 1st Generation Rear Wheels Replacement: étape 4, image 3 de 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
Emily Imfeld
Membre depuis le 10/06/16
532 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 15-7, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 13
Total : 1,288
