Aller au contenu principal
Boosted Board 1st Generation Skateboard Bearings Replacement
Ce dont vous avez besoin
  1. Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: étape 1, image 1 de 2 Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: étape 1, image 2 de 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Skateboard Bearings Replacement: étape 2, image 1 de 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Skateboard Bearings Replacement: étape 3, image 1 de 2 Boosted Board 1st Generation Skateboard Bearings Replacement: étape 3, image 2 de 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Skateboard Bearings Replacement: étape 4, image 1 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: étape 4, image 2 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: étape 4, image 3 de 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: étape 5, image 1 de 2 Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: étape 5, image 2 de 2
    • Use one finger to pull out the pulley bearing.
    • A good technique is to go around in a circle and lift from underneath the bearing in a carving motion.
  6. Boosted Board 1st Generation Skateboard Bearings Replacement: étape 6, image 1 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: étape 6, image 2 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: étape 6, image 3 de 3
    • Use an Allen wrench to apply pressure to the inside edge of the bearing until it pops out
  7. Boosted Board 1st Generation Skateboard Bearings Replacement: étape 7, image 1 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: étape 7, image 2 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: étape 7, image 3 de 3
    • Replace bearing by dropping it in the center of the wheel and use a socket wrench to pop in back it place
  8. Boosted Board 1st Generation Skateboard Bearings Replacement: étape 8, image 1 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: étape 8, image 2 de 3 Boosted Board 1st Generation Skateboard Bearings Replacement: étape 8, image 3 de 3
    • Slide the bearing spacer on to an Allen wrench
    • Align the Allen wrench in the center of the bearing and drop the spacer directly in the middle
    • Repeat Step 7 for placing the bearing in this side of the wheel.
To reassemble your device, follow these directions in reverse order.
Emily Imfeld
Membre depuis le 10/06/16
532 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 15-7, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 8
Total : 731
