Aller au contenu principal
Bosch 3727DEVS Governor Replacement
Ce dont vous avez besoin
  1. Bosch 3727DEVS Governor Replacement, Governor: étape 1, image 1 de 3 Bosch 3727DEVS Governor Replacement, Governor: étape 1, image 2 de 3 Bosch 3727DEVS Governor Replacement, Governor: étape 1, image 3 de 3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top off of the sander.
  2. Bosch 3727DEVS Governor Replacement: étape 2, image 1 de 3 Bosch 3727DEVS Governor Replacement: étape 2, image 2 de 3 Bosch 3727DEVS Governor Replacement: étape 2, image 3 de 3
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift the cable clip and cord from motor housing.
  3. Bosch 3727DEVS Governor Replacement: étape 3, image 1 de 1
    • Lift the On/Off switch out of the device
    • Remove the gray and purple wires
  4. Bosch 3727DEVS Governor Replacement: étape 4, image 1 de 2 Bosch 3727DEVS Governor Replacement: étape 4, image 2 de 2
    • Remove the gray, brown, and clear wires by pulling on the wire terminals.
    • Lift the Governor out of the housing.
Daniel Riddle
Membre depuis le 01/29/16
331 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 14
Total : 574
