Aller au contenu principal
Bosch 3727DEVS Motor Brushes Replacement
Ce dont vous avez besoin
  1. Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: étape 1, image 1 de 3 Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: étape 1, image 2 de 3 Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: étape 1, image 3 de 3
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top cover off the sander.
  2. Bosch 3727DEVS Motor Brushes  Replacement: étape 2, image 1 de 3 Bosch 3727DEVS Motor Brushes  Replacement: étape 2, image 2 de 3 Bosch 3727DEVS Motor Brushes  Replacement: étape 2, image 3 de 3
    • Remove the two white wires connected to each motor brush by pulling on the spade terminals.
  3. Bosch 3727DEVS Motor Brushes  Replacement: étape 3, image 1 de 3 Bosch 3727DEVS Motor Brushes  Replacement: étape 3, image 2 de 3 Bosch 3727DEVS Motor Brushes  Replacement: étape 3, image 3 de 3
    • Using the T10 Torx Screwdriver, remove the four 9.7 mm screws securing the motor brushes to the housing.
    • After the screws are removed, both motor brushes can be lifted out of their position by hand.
Daniel Riddle
Membre depuis le 01/29/16
331 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 26
Total : 1,020
