Aller au contenu principal
  1. The drill has a failure in the tightening of the bit, which doesn't allow the bit to function correctly The drill has a failure in the tightening of the bit, which doesn't allow the bit to function correctly The drill has a failure in the tightening of the bit, which doesn't allow the bit to function correctly
    • The drill has a failure in the tightening of the bit, which doesn't allow the bit to function correctly
  2. What tools you'll need: Socket wrench with flat point, precision screw driver, flathead screw driver, computer, additional tools. Loosen tools that hold the frame of the drill. Once removed, use the flat head screw driver to pry the sides apart. Once the sides are separated, use a larger flat head screw driver to completely separate the shell. Be sure to remove all screws. Here we see the internals of the drill
    • What tools you'll need: Socket wrench with flat point, precision screw driver, flathead screw driver, computer, additional tools.
    • Loosen tools that hold the frame of the drill. Once removed, use the flat head screw driver to pry the sides apart. Once the sides are separated, use a larger flat head screw driver to completely separate the shell. Be sure to remove all screws.
    • Here we see the internals of the drill
  3. View of motor and gears View of the top switch Closer view of the top switch
    • View of motor and gears
    • View of the top switch
    • Closer view of the top switch
  4. Studying the way it works Dismantle the drive head using the large flat head to leverage. Switch removed
    • Studying the way it works
    • Dismantle the drive head using the large flat head to leverage.
    • Switch removed
  5. View of the dirty internals Removal of the grips by pressing these levers Discovery of the broken part
    • View of the dirty internals
    • Removal of the grips by pressing these levers
    • Discovery of the broken part
  6. A closer look at the broken part The mechanism of the grips The mechanism of the grips
    • A closer look at the broken part
    • The mechanism of the grips
  7. Grip mechanism and gears up close Grip mechanism and gears up close Grip mechanism and gears up close
    • Grip mechanism and gears up close
  8. Identifying the missing piece that fell out Consulting the manual to find the correct place of this piece Cleaning with a dust pan and brush in gasoline
    • Identifying the missing piece that fell out
    • Consulting the manual to find the correct place of this piece
    • Cleaning with a dust pan and brush in gasoline
  9. Clean outer shell, internals, and see all pieces of the drill Clean outer shell, internals, and see all pieces of the drill Clean outer shell, internals, and see all pieces of the drill
    • Clean outer shell, internals, and see all pieces of the drill
  10. Grease the gears Find and replace all hidden parts found by cleaning with gasoline Replacing the drill grip on the main body
    • Grease the gears
    • Find and replace all hidden parts found by cleaning with gasoline
    • Replacing the drill grip on the main body
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Alfredo Takapum
Membre depuis le 12/12/2018
1 Réputation
1 tutoriel rédigé
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 31
