Aller au contenu principal
Bose Cinemate 10 Circuit Board Replacement
Ce dont vous avez besoin
  1. Bose Cinemate 10 Circuit Board Replacement, Circuit Board: étape 1, image 1 de 2 Bose Cinemate 10 Circuit Board Replacement, Circuit Board: étape 1, image 2 de 2
    • Locate the cable input port, on the back of the device.
    • Remove the 2, PH1, 15mm screws.
  2. Bose Cinemate 10 Circuit Board Replacement: étape 2, image 1 de 3 Bose Cinemate 10 Circuit Board Replacement: étape 2, image 2 de 3 Bose Cinemate 10 Circuit Board Replacement: étape 2, image 3 de 3
    • Gently, pull the base of the A/V cable directly outward, away from the main body of the device.
    • Slide the plastic cover to the right, which should free the cover from the main body of the device.
  3. Bose Cinemate 10 Circuit Board Replacement: étape 3, image 1 de 3 Bose Cinemate 10 Circuit Board Replacement: étape 3, image 2 de 3 Bose Cinemate 10 Circuit Board Replacement: étape 3, image 3 de 3
    • Using your fingers, gently pull outward on the multi-colored wire bundle until the black plastic wire harness is visible.
    • Press on the latch on the black plastic wire harness, and pull the multi-colored wire bundle simultaneously. The cables should now be detached from the harness.
  4. Bose Cinemate 10 Circuit Board Replacement: étape 4, image 1 de 3 Bose Cinemate 10 Circuit Board Replacement: étape 4, image 2 de 3 Bose Cinemate 10 Circuit Board Replacement: étape 4, image 3 de 3
    • Using your fingers, grasp the edges of cable input port.
    • Gently pull the cable input port away from main body of device. The Circuit Board should now be completely separated from the main body of the device.
  5. Bose Cinemate 10 Circuit Board Replacement: étape 5, image 1 de 3 Bose Cinemate 10 Circuit Board Replacement: étape 5, image 2 de 3 Bose Cinemate 10 Circuit Board Replacement: étape 5, image 3 de 3
    • Press the tab on side of white plastic cable harness, and pull gently on the multi-colored wire bundle simultaneously. The cable should completely detach from the Circuit Board.
2 autres ont terminé cette réparation.
Phillip Halverson
Membre depuis le 09/26/18
335 Réputation
2 tutoriels rédigés
3 commentaires
Where do I buy the circuit board from.
frankiemo239 - Réponse
Where do I find the circuit board from
Where can I buy a circuit board?
jeanne768 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 24
Total : 1,970
