Aller au contenu principal
Bose On-Ear headphones Ear Cushion Replacement
Ce dont vous avez besoin
  1. Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: étape 1, image 1 de 3 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: étape 1, image 2 de 3 Bose On-Ear headphones Ear Cushion Replacement, Ear Cushion: étape 1, image 3 de 3
    • Here is the Bose Tricore OE headset. Slightly worn and a torn left ear cushion
    • To remove an existing ear cushion one would simply be applying a bit of force between the ear pads and the housing. The ear cushion will simply snap off
    • This shows the snaps that attach the ear pad to the case.
  2. Bose On-Ear headphones Ear Cushion Replacement: étape 2, image 1 de 3 Bose On-Ear headphones Ear Cushion Replacement: étape 2, image 2 de 3 Bose On-Ear headphones Ear Cushion Replacement: étape 2, image 3 de 3
    • Since the ear cushion was already torn off on this one, simply clean the mating surfaces from all debris left by the old ear cushion
    • All left over foam and adhesive tape needs to be removed. This will ensure a proper fit.
    • Here is a look at the back of the replacement cushion.
  3. Bose On-Ear headphones Ear Cushion Replacement: étape 3, image 1 de 3 Bose On-Ear headphones Ear Cushion Replacement: étape 3, image 2 de 3 Bose On-Ear headphones Ear Cushion Replacement: étape 3, image 3 de 3
    • Position the cushion so that the orientation aligns the two holes with the two pins on the headphones.
    • Place the new ear cushion on the headphones ensuring the holes and pins are lined up.
    • A simple squeeze on the ear cushion will snap the plastic to the headphones.
  4. Bose On-Ear headphones Ear Cushion Replacement: étape 4, image 1 de 1
    • Good as new and ready to jam!
oldturkey03
Membre depuis le 09/29/10
784 351 Réputation
119 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
33 membres
560 tutoriels rédigés
Un commentaire
Thanks for showing the steps
Rajiv Garg - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 59
Total : 7,329
