Aller au contenu principal
Bose Solo 5 Sound Bar Speaker Replacement
Ce dont vous avez besoin
  1. Bose Solo 5 Sound Bar Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Lay Bose Solo 5 on its top side with the speakers facing away from you.
  2. Bose Solo 5 Sound Bar Speaker Replacement: étape 2, image 1 de 2 Bose Solo 5 Sound Bar Speaker Replacement: étape 2, image 2 de 2
    • Remove the two screws located at the outer edge of the backside with a Phillips head screwdriver.
  3. Bose Solo 5 Sound Bar Speaker Replacement: étape 3, image 1 de 1
    • Lay the speaker on its backside with the speakers facing up. Wedge the plastic opening tool into the crack where the protective wire screen meets the housing. Pry apart until you create enough room for your fingers.
  4. Bose Solo 5 Sound Bar Speaker Replacement: étape 4, image 1 de 2 Bose Solo 5 Sound Bar Speaker Replacement: étape 4, image 2 de 2
    • Pull the screen gently away from the housing to reveal the two speakers with your fingers.
  5. Bose Solo 5 Sound Bar Speaker Replacement: étape 5, image 1 de 3 Bose Solo 5 Sound Bar Speaker Replacement: étape 5, image 2 de 3 Bose Solo 5 Sound Bar Speaker Replacement: étape 5, image 3 de 3
    • Remove the 4 screws in each corner of the speaker to remove it from the housing.
  6. Bose Solo 5 Sound Bar Speaker Replacement: étape 6, image 1 de 2 Bose Solo 5 Sound Bar Speaker Replacement: étape 6, image 2 de 2
    • Peel back the styrofoam on the speaker & disconnect the yellow & brown wires by sliding them off the receptor.
3 autres ont terminé cette réparation.
Chase Cooper
Membre depuis le 10/09/18
220 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team S15-G7, Blackburne Fall 2018 Membre de l'équipe Sam Houston State, Team S15-G7, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G7
2 membres
5 tutoriels rédigés
Un commentaire
Well opening the case affect its original sound tuning or will it affect the performance ?
Saket Adhau - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 22
30 derniers jours : 103
Total : 14,136
