Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Bose SoundDock Portable v2 Battery Replacement
Ce dont vous avez besoin
    1. Bose SoundDock Portable v2 Battery Replacement, Battery: étape 1, image 1 de 1
      • Using your thumbnail or a coin, push in the slotted knob on the battery and turn it counterclockwise to unlock the battery.
      Demander à FixBot
      Ajouter un commentaire
    2. Bose SoundDock Portable v2 Battery Replacement: étape 2, image 1 de 1
      • Carefully pull the battery away from the back of the system.
      Demander à FixBot
    3. Bose SoundDock Portable v2 Battery Replacement: étape 3, image 1 de 1
      • On the new battery, make sure the slot in the knob on the battery is in a horizontal position.
      • Insert the battery into the multi-pin connector.
      Demander à FixBot
    4. Bose SoundDock Portable v2 Battery Replacement: étape 4, image 1 de 1
      • Push in the slotted knob and turn it clockwise until the slot is vertical. This locks the battery in place.
      Demander à FixBot
    5. Bose SoundDock Portable v2 Battery Replacement: étape 5, image 1 de 1
      • Connect the power supply and charge the battery.
      Demander à FixBot
4 autres ont terminé cette réparation.
Evan Low
Membre depuis le 04/14/15
584 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 4-1, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 membres
35 tutoriels rédigés
8 commentaires de tutoriel
I think it would be cool to show a Teardown of the Bose SoundDock Portable v2 Battery.
Joseph Gorse - Réponse Partager
I agree. These batteries seem prone to failure and I’d like to replace the cells or whatever it is that is the failure point.
adam-marsh - Réponse Partager
Thanks for your easy and concise help.
Stuart Friedman - Réponse Partager
Battery is repairable.
There are 4 screws under plastic plugs under sticker. They are one way heads :( use force or a drill.
Locking thingy removal - push the cross pin through - pliers or vise grips to grab and pull out completely. Keep an eye on where spring went.
There may be a bit of glue or tape holding cover too.
4 x 18650 Li-ion cells in 2 banks at each side of the charging board which is held down by 5 screws. Some adhesive was used to hold the cells to the back.
Use meter to check. Mine had one cell at 0V so that was the culprit.
Remove any bad cells by cutting the glue about the temp sensors to carefully get them out of the way. Then cut the cell tags - careful not to short anything as there is charge about. I found it faster to cut tags but you could unglue all cells and lift the board and do that way. My replacement cell came from a Dell laptop pack. Glue the new battery in place (I used automotive trim tape as it was handy) and solder the new cell. Reglue temp sensors.
Reassemble with some new screws.
Affeke Nommu - Réponse Partager
Hi. How do you push the cross pin through? I can’t
Enrique Francis - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 22
30 derniers jours : 104
Total : 28,195
