Aller au contenu principal
Bose SoundLink Color Speaker Replacement
Ce dont vous avez besoin
  1. Bose SoundLink Color Speaker Replacement, Outer Casing: étape 1, image 1 de 2 Bose SoundLink Color Speaker Replacement, Outer Casing: étape 1, image 2 de 2
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
  2. Bose SoundLink Color Speaker Replacement: étape 2, image 1 de 2 Bose SoundLink Color Speaker Replacement: étape 2, image 2 de 2
    • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
    • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
  3. Bose SoundLink Color Speaker Replacement: étape 3, image 1 de 2 Bose SoundLink Color Speaker Replacement: étape 3, image 2 de 2
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
  4. Bose SoundLink Color Speaker Replacement, Speaker: étape 4, image 1 de 2 Bose SoundLink Color Speaker Replacement, Speaker: étape 4, image 2 de 2
    • Lift up the retaining flap on the button cable ZIF connector.
    • Pull the button cable straight out of the connector.
    • Remove the inner assembly.
  5. Bose SoundLink Color Speaker Replacement: étape 5, image 1 de 1
    • The speakers are on the front of the inner assembly.
    • Using the Phillips head screwdriver, unscrew the four 1.3 cm screws holding the speaker that will be replaced.
  6. Bose SoundLink Color Speaker Replacement: étape 6, image 1 de 2 Bose SoundLink Color Speaker Replacement: étape 6, image 2 de 2
    • Three screws hold the printed circuit board.
    • Using the Phillips head screwdriver, unscrew the three 1.2 cm screws.
  7. Bose SoundLink Color Speaker Replacement: étape 7, image 1 de 2 Bose SoundLink Color Speaker Replacement: étape 7, image 2 de 2
    • Desolder each the three pins connecting the speaker to the motherboard.
    • Carefully lift the motherboard with a spudger to ensure that each pin desolders.
    • Work carefully. Prying too hard may cause damage to the board.
  8. Bose SoundLink Color Speaker Replacement: étape 8, image 1 de 1
    • Push the speaker through the front of the inner assembly.
19 autres ont terminé cette réparation.
Brett Horstketter
Membre depuis le 03/31/16
2 738 Réputation
1 tutoriel rédigé
12 commentaires
Thanks for this tear down. Never thought that it looks like this on the inside. My battery is kind off aging, bought the unit 7 months ago. Local Bose dealer said battery cost half of this speaker. I hope there is a cheaper alternative.
vintiglao22 - Réponse
You can unsolder the battery and replace with a standard unprotected 18650 cell it literally costs 7$ for a high quality sony or panasonic or samsung cell. The protection and charging circuit is included in the speaker motherboard just make sure you resolder with the proper polarity.
swiftink -
Como ago para traducir cada
luis beltran - Réponse
Speaker looks like a 18650 lithium ion- from the pictures here.
DR Paquette - Réponse
Does anybody know where one could order a spare speaker for this device?
sebastiansebisilva - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 79
30 derniers jours : 266
Total : 30,026
