Introduction
If you are experiencing any audio issues with the higher frequency sounds (the treble) such as distortion, muffling, quietness, or total absence of sound, you may need to replace one or more of your treble speakers.
Ce dont vous avez besoin
Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
Gently peel back the adhesive padding on either side of the inner back panel.
For each of the 4 treble speakers you must uncoil the red wire and black wire in order to remove them.
5 autres ont terminé cette réparation.
