Aller au contenu principal
Bose SoundLink Mini Front/Back Protective Grille Replacement
Ce dont vous avez besoin
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: étape 1, image 1 de 1
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: étape 2, image 1 de 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: étape 2, image 2 de 2
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: étape 3, image 1 de 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: étape 3, image 2 de 2
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: étape 4, image 1 de 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: étape 4, image 2 de 2
    • Repeat steps to remove the back grille.
9 autres ont terminé cette réparation.
Jordan Smith
Membre depuis le 10/01/15
880 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 1-23, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 membres
21 tutoriels rédigés
6 commentaires
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - Réponse
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - Réponse
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - Réponse
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 25
30 derniers jours : 94
Total : 11,787
