Introduction
If the audio from your SoundTouch 10 is muffled, distorted, or completely silent, you may need to replace the speaker entirely. Be careful when handling the motherboard as it contains capacitors which may hold a charge even while the speaker is unplugged.
Ce dont vous avez besoin
Turn the speaker over so that the rubber strips along the bottom are facing you.
Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
Use a #2 Phillips screwdriver to remove each of the four 15mm screws holding the speaker in place.
4 autres ont terminé cette réparation.
4 commentaires
Hi I need to get a replacement for the driver. Would you know the specs or where to get them from? Bose support has not been very helpful with this , since I live outside of the US and repair would be expensive, I need to purchase the driver only to fix it myself. Any advise would be appreciated.
Hello I needed to reconnect my capacitor on my Bose Soundtouch 10 after dropping speaker. The IFixit steps to open the speaker were perfect! After reconnecting capacitor, shaking the speaker was no longer required.
BillJ - 06/30/20
