Aller au contenu principal
Bose SoundTouch Portable Motherboard Replacement
Ce dont vous avez besoin
  1. Bose SoundTouch Portable Motherboard Replacement, Speaker Battery: étape 1, image 1 de 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Motherboard Replacement: étape 2, image 1 de 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Motherboard Replacement: étape 3, image 1 de 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Motherboard Replacement, Metal Trim: étape 4, image 1 de 1
    • Remove the two screws using a torx screwdriver.
  5. Bose SoundTouch Portable Motherboard Replacement: étape 5, image 1 de 1
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  6. Bose SoundTouch Portable Motherboard Replacement, Motherboard: étape 6, image 1 de 2 Bose SoundTouch Portable Motherboard Replacement, Motherboard: étape 6, image 2 de 2
    • Remove four T-10 Torx screws; there are two on the front and two on the back.
  7. Bose SoundTouch Portable Motherboard Replacement: étape 7, image 1 de 3 Bose SoundTouch Portable Motherboard Replacement: étape 7, image 2 de 3 Bose SoundTouch Portable Motherboard Replacement: étape 7, image 3 de 3
    • Pinch and remove the connectors.
    • Use a flat tool to pry off the top piece.
  8. Bose SoundTouch Portable Motherboard Replacement: étape 8, image 1 de 3 Bose SoundTouch Portable Motherboard Replacement: étape 8, image 2 de 3 Bose SoundTouch Portable Motherboard Replacement: étape 8, image 3 de 3
    • Remove the four T-10 Torx screws holding the plastic cover in place.
    • Remove the one T-10 Torx screw that is holding the motherboard in place.
    • Pry off the motherboard.
2 autres ont terminé cette réparation.
Chelsea Martin
Membre depuis le 02/20/17
697 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Leahy Spring 2017 Membre de l'équipe USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 32
Total : 2,971
