Aller au contenu principal
Bose SoundTouch Portable Speaker Replacement
Ce dont vous avez besoin
  1. Bose SoundTouch Portable Speaker Replacement, Speaker Battery: étape 1, image 1 de 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Speaker Replacement: étape 2, image 1 de 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Speaker Replacement: étape 3, image 1 de 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Speaker Replacement, Grille: étape 4, image 1 de 1
    • Remove the two screws holding the speaker grille in place.
  5. Bose SoundTouch Portable Speaker Replacement: étape 5, image 1 de 1
    • Grip the sides of the device and push the speaker grille down and out.
  6. Bose SoundTouch Portable Speaker Replacement: étape 6, image 1 de 1
    • Gently release the ribbon from its connector and remove the grille.
  7. Bose SoundTouch Portable Speaker Replacement, Speakers: étape 7, image 1 de 1
    • There are four T-10 Torx screws for each speaker; remove all four screws for each speaker you are replacing.
  8. Bose SoundTouch Portable Speaker Replacement: étape 8, image 1 de 3 Bose SoundTouch Portable Speaker Replacement: étape 8, image 2 de 3 Bose SoundTouch Portable Speaker Replacement: étape 8, image 3 de 3
    • Using a plastic pry tool, carefully pry the speaker up.
    • With the bottom of the speaker exposed, unwind the wires from the connection tabs and replace the speaker.
Chelsea Martin
Membre depuis le 02/20/17
697 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Leahy Spring 2017 Membre de l'équipe USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 14
Total : 1,814
