Aller au contenu principal
Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement
Ce dont vous avez besoin
  1. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement, Speaker Battery: étape 1, image 1 de 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement: étape 2, image 1 de 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement: étape 3, image 1 de 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement, Metal Trim: étape 4, image 1 de 1
    • Remove the two screws using a torx screwdriver.
  5. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement: étape 5, image 1 de 1
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  6. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement, USB/AC Adapter and AUX Cord: étape 6, image 1 de 3 Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement, USB/AC Adapter and AUX Cord: étape 6, image 2 de 3 Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement, USB/AC Adapter and AUX Cord: étape 6, image 3 de 3
    • Remove the two T-10 Torx screws
    • Remove the black casing
    • Pry off flat connector
2 autres ont terminé cette réparation.
Chelsea Martin
Membre depuis le 02/20/17
697 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Leahy Spring 2017 Membre de l'équipe USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 1,631
