Introduction
A very easy component to replace on the Bose Soundlink Flex is the charging port. If your speaker fails to charge, then your charging port might be broken. Otherwise, dust and sediment may have accumulated and needs to be cleaned out. The charging port is USB C, common in most Android devices.
Ce dont vous avez besoin
Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
Lift the driver out, being cautious of the wires still connected to the device.
