Aller au contenu principal
Bose Soundlink Flex Grille Replacement
Ce dont vous avez besoin
  1. Bose Soundlink Flex Grille Replacement, Grille: étape 1, image 1 de 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
  2. Bose Soundlink Flex Grille Replacement: étape 2, image 1 de 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
  3. Bose Soundlink Flex Grille Replacement: étape 3, image 1 de 2 Bose Soundlink Flex Grille Replacement: étape 3, image 2 de 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
Isaac
Membre depuis le 10/30/23
205 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 Membre de l'équipe UMass Dartmouth, Team 4-1, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 177
