Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Bose Soundlink Revolve AUX/USB Port Replacement
Ce dont vous avez besoin
  1. Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: étape 1, image 1 de 2 Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: étape 1, image 2 de 2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve AUX/USB Port Replacement: étape 2, image 1 de 3 Bose Soundlink Revolve AUX/USB Port Replacement: étape 2, image 2 de 3 Bose Soundlink Revolve AUX/USB Port Replacement: étape 2, image 3 de 3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve AUX/USB Port Replacement: étape 3, image 1 de 2 Bose Soundlink Revolve AUX/USB Port Replacement: étape 3, image 2 de 2
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve AUX/USB Port Replacement: étape 4, image 1 de 2 Bose Soundlink Revolve AUX/USB Port Replacement: étape 4, image 2 de 2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: étape 5, image 1 de 3 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: étape 5, image 2 de 3 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: étape 5, image 3 de 3
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
16 autres ont terminé cette réparation.
Brian Butner
Membre depuis le 09/27/17
927 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S6-G2, Remmell Fall 2017 Membre de l'équipe USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 membres
4 tutoriels rédigés
17 commentaires de tutoriel
Any idea where I can find the USB/Aux board for sale?
Chad - Réponse Partager
Did you ever manage to find a place to buy it?
Steve Fantin - Partager
You can buy a charging cradle for this device, maybe that helps..
adsf - Partager
Try buying the wireless charger for $29: https://www.bose.com/en_us/products/spea...
Reynolds Cameron - Partager
I am also looking for the usb port replacement part.
James Nowicki - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 65
30 derniers jours : 231
Total : 38,659
