Aller au contenu principal
Bose Wave Radio AWR1-1W Screen Replacement
Ce dont vous avez besoin
  1. Bose Wave Radio AWR1-1W Screen Replacement, Base: étape 1, image 1 de 2 Bose Wave Radio AWR1-1W Screen Replacement, Base: étape 1, image 2 de 2
    • Remove the four 19mm Phillips #2 screws from the base of the device.
  2. Bose Wave Radio AWR1-1W Screen Replacement: étape 2, image 1 de 3 Bose Wave Radio AWR1-1W Screen Replacement: étape 2, image 2 de 3 Bose Wave Radio AWR1-1W Screen Replacement: étape 2, image 3 de 3
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
  3. Bose Wave Radio AWR1-1W Screen Replacement: étape 3, image 1 de 3 Bose Wave Radio AWR1-1W Screen Replacement: étape 3, image 2 de 3 Bose Wave Radio AWR1-1W Screen Replacement: étape 3, image 3 de 3
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
  4. Bose Wave Radio AWR1-1W Screen Replacement: étape 4, image 1 de 3 Bose Wave Radio AWR1-1W Screen Replacement: étape 4, image 2 de 3 Bose Wave Radio AWR1-1W Screen Replacement: étape 4, image 3 de 3
    • Pinch and unplug the white connector from the device.
  5. Bose Wave Radio AWR1-1W Screen Replacement: étape 5, image 1 de 3 Bose Wave Radio AWR1-1W Screen Replacement: étape 5, image 2 de 3 Bose Wave Radio AWR1-1W Screen Replacement: étape 5, image 3 de 3
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
  6. Bose Wave Radio AWR1-1W Screen Replacement: étape 6, image 1 de 1
    • The base should now be completely detached from the device.
  7. Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: étape 7, image 1 de 3 Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: étape 7, image 2 de 3 Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: étape 7, image 3 de 3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  8. Bose Wave Radio AWR1-1W Screen Replacement: étape 8, image 1 de 3 Bose Wave Radio AWR1-1W Screen Replacement: étape 8, image 2 de 3 Bose Wave Radio AWR1-1W Screen Replacement: étape 8, image 3 de 3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  9. Bose Wave Radio AWR1-1W Screen Replacement: étape 9, image 1 de 1
    • Lift the front grill away from the device.
  10. Bose Wave Radio AWR1-1W Screen Replacement, Button Panel: étape 10, image 1 de 2 Bose Wave Radio AWR1-1W Screen Replacement, Button Panel: étape 10, image 2 de 2
    • Turn the device around.
    • Wedge the spudger into the larger part of the gap under the back of the device.
  11. Bose Wave Radio AWR1-1W Screen Replacement: étape 11, image 1 de 1
    • Move the spudger up until the button panel is loose.
    • Push forward on the back of the button panel to disconnect the panel from the top of the device.
  12. Bose Wave Radio AWR1-1W Screen Replacement: étape 12, image 1 de 2 Bose Wave Radio AWR1-1W Screen Replacement: étape 12, image 2 de 2
    • Pull the button panel forward with one hand and push the screen assembly into the device with the other to disconnect the button panel.
  13. Bose Wave Radio AWR1-1W Screen Replacement, Screen: étape 13, image 1 de 3 Bose Wave Radio AWR1-1W Screen Replacement, Screen: étape 13, image 2 de 3 Bose Wave Radio AWR1-1W Screen Replacement, Screen: étape 13, image 3 de 3
    • Gently pull the top of the screen assembly away from the device.
  14. Bose Wave Radio AWR1-1W Screen Replacement: étape 14, image 1 de 2 Bose Wave Radio AWR1-1W Screen Replacement: étape 14, image 2 de 2
    • Lift the screen assembly upward and pull the white wire strip out of the device.
4 autres ont terminé cette réparation.
Cassie Harriman
Membre depuis le 04/18/17
1 033 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S15-G2, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S15-G2, Banghart Spring 2017
CPSU-BANGHART-S17S15G2
4 membres
6 tutoriels rédigés
5 commentaires
Great! This device is the best wave system in sound accurate. All frequencies sounds clear!!! Awesome!!!
srmrs - Réponse
Nicely done.  Love the details.  Just one question - where can I get the replacement screen?
Patsy Hamilton - Réponse
Instructions were PERFECT! Thank you. I found my replacement screen on ebay for $25, took a chance that it would work as stated by the seller. Otherwise I would have thrown the radio away.
John Stine - Réponse
I performed the repair as directed. It was easy especially if you have a plastic spung to work with. Problem comes from the new display once installed shows all the characters? Unplugged it and re-plugged but still stuck in all character test mode?
plhamp - Réponse
How to purchase White wire strip
Bruce Ebneter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 40
30 derniers jours : 116
Total : 10,013
