Aller au contenu principal
Bose-301 Series II Tweeter Replacement
Ce dont vous avez besoin
  1. Bose-301 Series II Tweeter Replacement, Tweeter: étape 1, image 1 de 3 Bose-301 Series II Tweeter Replacement, Tweeter: étape 1, image 2 de 3 Bose-301 Series II Tweeter Replacement, Tweeter: étape 1, image 3 de 3
    • Begin the repair by placing the Bose-301 speaker vertically.
    • Using two hands, pull the speaker grill towards you and away from the speaker body.
  2. Bose-301 Series II Tweeter Replacement: étape 2, image 1 de 1
    • Pull the main speaker grill towards you to remove it from the body structure.
  3. Bose-301 Series II Tweeter Replacement: étape 3, image 1 de 3 Bose-301 Series II Tweeter Replacement: étape 3, image 2 de 3 Bose-301 Series II Tweeter Replacement: étape 3, image 3 de 3
    • Lay the speaker body on its back.
    • Using the Philips Screwdriver, carefully remove the four #2x19mm screws that mount the main speaker to the speaker body.
  4. Bose-301 Series II Tweeter Replacement: étape 4, image 1 de 2 Bose-301 Series II Tweeter Replacement: étape 4, image 2 de 2
    • Untwist the slack in the wires that are connected to the main speaker.
  5. Bose-301 Series II Tweeter Replacement: étape 5, image 1 de 3 Bose-301 Series II Tweeter Replacement: étape 5, image 2 de 3 Bose-301 Series II Tweeter Replacement: étape 5, image 3 de 3
    • Carefully place the speaker off to the side.
    • Be sure to not place the speaker face down or put pressure on the speaker cone as this can damage the cone.
    • Be aware of the very strong magnet in the driver of the speaker, which can cause damage to electronic devices in close proximity.
    • Then untwist the slack in the wires that are connected to the tweeters.
  6. Bose-301 Series II Tweeter Replacement: étape 6, image 1 de 1
    • Using the socket wrench and the 1/4" socket, unscrew the 12.5 mm bolt that mounts the tweeter to the bracket.
  7. Bose-301 Series II Tweeter Replacement: étape 7, image 1 de 1
    • While holding the tweeter, use your other hand to feed the wire through the hole at the bottom of the tweeter mount.
  8. Bose-301 Series II Tweeter Replacement: étape 8, image 1 de 2 Bose-301 Series II Tweeter Replacement: étape 8, image 2 de 2
    • Remove the tweeter from the mount and locate the two wires that connect it to the speaker.
    • Using the pliers, untwist the wires that are attached to the two small rods at the bottom of the tweeter.
    • Repeat process for the second tweeter.
    • Be sure not to excessively bend the bare wires in order to reuse it for the replacement tweeters.
To reassemble your speaker, follow these instructions in reverse order.
3 autres ont terminé cette réparation.
Patrick Emery
Membre depuis le 01/09/17
174 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 15-3, Remmell Spring 2017 Membre de l'équipe USF Tampa, Team 15-3, Remmell Spring 2017
USFT-REMMELL-S17S15G3
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 54
Total : 7,189
