Aller au contenu principal
Boss RC-1 Loop Station-Pedal Battery Replacement
Ce dont vous avez besoin
  1. Boss RC-1 Loop Station-Pedal Battery Replacement, Battery: étape 1, image 1 de 1
    • Push down on the pedal in order to relieve pressure on the thumbscrew.
  2. Boss RC-1 Loop Station-Pedal Battery Replacement: étape 2, image 1 de 1
    • Remove the thumb screw at the bottom of the device.
    • Loosening the thumb screw far enough will also allow the pedal to open.
  3. Boss RC-1 Loop Station-Pedal Battery Replacement: étape 3, image 1 de 2 Boss RC-1 Loop Station-Pedal Battery Replacement: étape 3, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the two screws that secure the pedal to the device.
  4. Boss RC-1 Loop Station-Pedal Battery Replacement: étape 4, image 1 de 1
    • Take the battery out of the device.
  5. Boss RC-1 Loop Station-Pedal Battery Replacement: étape 5, image 1 de 1
    • Disconnect the snap chord from the battery.
  6. Boss RC-1 Loop Station-Pedal Battery Replacement: étape 6, image 1 de 1
    • Reassemble the device in the opposite order.
    • When tightening the thumbscrew back in the device, apply force to the pedal first (Do step 1 before step 2).
To check if the batter replacement was successful, plug in a guitar cable into the “Output A” jack. If the red light turns on below the “check” (top of the device), then the looper pedal is working.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 21
30 derniers jours : 102
Total : 5,393
