Aller au contenu principal
Bowers and Wilkins T7 Access Panel Replacement
Ce dont vous avez besoin
  1. Bowers and Wilkins T7 Access Panel Replacement, Access Panel: étape 1, image 1 de 1
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
  2. Bowers and Wilkins T7 Access Panel Replacement: étape 2, image 1 de 1
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
  3. Bowers and Wilkins T7 Access Panel Replacement: étape 3, image 1 de 2 Bowers and Wilkins T7 Access Panel Replacement: étape 3, image 2 de 2
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Access Panel Replacement: étape 4, image 1 de 2 Bowers and Wilkins T7 Access Panel Replacement: étape 4, image 2 de 2
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
  5. Bowers and Wilkins T7 Access Panel Replacement: étape 5, image 1 de 3 Bowers and Wilkins T7 Access Panel Replacement: étape 5, image 2 de 3 Bowers and Wilkins T7 Access Panel Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
2 autres ont terminé cette réparation.
Shane R. Cowper
Membre depuis le 03/02/17
131 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S7-G1, Cagle Spring 2017 Membre de l'équipe USF Tampa, Team S7-G1, Cagle Spring 2017
USFT-CAGLE-S17S7G1
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 28
Total : 2,987
