Aller au contenu principal
Braun Aromaster KF440 one-way valve Replacement
Ce dont vous avez besoin
  1. Braun Aromaster KF440 one-way valve Replacement, Access the base: étape 1, image 1 de 1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 one-way valve Replacement, Remove the nut: étape 2, image 1 de 1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 one-way valve Replacement, Remove the cover: étape 3, image 1 de 1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
  4. Braun Aromaster KF440 one-way valve Replacement, Locate internal one-way valve: étape 4, image 1 de 1
    • Locate the one-way valve.
  5. Braun Aromaster KF440 one-way valve Replacement, Pull out valve: étape 5, image 1 de 1
    • Lift up on the one way valve to snap it out of place. (This shouldn't require much force).
  6. Braun Aromaster KF440 one-way valve Replacement, Push tube off the one-way valve: étape 6, image 1 de 1
    • Using the larger plastic opening tool, gently push the tubing off of the one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
  7. Braun Aromaster KF440 one-way valve Replacement, Lift valve: étape 7, image 1 de 1
    • Completely remove one-way valve from the inside of the coffee maker.
3 autres ont terminé cette réparation.
Dennis
Membre depuis le 10/20/14
315 Réputation
2 tutoriels rédigés
Équipe
Baylor, Team 8-12, Williams Fall 2014 Membre de l'équipe Baylor, Team 8-12, Williams Fall 2014
BU-WILLIAMS-F14S8G12
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 36
Total : 3,348
