Aller au contenu principal
Braun BT3240 Electric Trimmer Battery Replacement
Ce dont vous avez besoin
  1. Braun BT3240 Electric Trimmer Battery Replacement, Battery: étape 1, image 1 de 1
    • Ensure that the charger is unplugged from the electrical outlet connected to the trimmer.
  2. Braun BT3240 Electric Trimmer Battery Replacement: étape 2, image 1 de 2 Braun BT3240 Electric Trimmer Battery Replacement: étape 2, image 2 de 2
    • Hold the trimmer in the opposite direction so that the power button on front is not facing you.
    • Separate the trimmer's top blade from the trimmer by pulling it in outwards direction.
  3. Braun BT3240 Electric Trimmer Battery Replacement: étape 3, image 1 de 3 Braun BT3240 Electric Trimmer Battery Replacement: étape 3, image 2 de 3 Braun BT3240 Electric Trimmer Battery Replacement: étape 3, image 3 de 3
    • Hold the trimmer sideways as this makes the process of prying easier.
    • Insert a Spudger or a sharp-tipped tweezer in between the top panel and middle panel and apply applicable force to unclip the plastic clips attaching the two panels.
    • Pull the top panel outwards and let it slide out of the middle panel. Do not try to force it out as this may break the plastic clips
  4. Braun BT3240 Electric Trimmer Battery Replacement: étape 4, image 1 de 3 Braun BT3240 Electric Trimmer Battery Replacement: étape 4, image 2 de 3 Braun BT3240 Electric Trimmer Battery Replacement: étape 4, image 3 de 3
    • Remove the four screws attaching the middle panel to the bottom panel.
  5. Braun BT3240 Electric Trimmer Battery Replacement: étape 5, image 1 de 2 Braun BT3240 Electric Trimmer Battery Replacement: étape 5, image 2 de 2
    • Use the Spudger or sharp tipped tweezer to separate the middle panel attached to the bottom panel by lifting it upwards.
  6. Braun BT3240 Electric Trimmer Battery Replacement: étape 6, image 1 de 2 Braun BT3240 Electric Trimmer Battery Replacement: étape 6, image 2 de 2
    • Gently pull out the battery holder connected to the electrical plug.
  7. Braun BT3240 Electric Trimmer Battery Replacement: étape 7, image 1 de 2 Braun BT3240 Electric Trimmer Battery Replacement: étape 7, image 2 de 2
    • Use a plier to pry off the battery contact tab which is soldered onto the battery. Repeat the same step for all 4 battery contact tabs (two on each side of the battery holder).
    • Be mindful not to completely destroy the battery contact tabs as you pry them off. You will need them while resoldering new batteries.
  8. Braun BT3240 Electric Trimmer Battery Replacement: étape 8, image 1 de 1
    • Caution! The temperature of the soldering iron is 450 degrees Fahrenheit. Do not apply melted soldering alloy for more than 15-20 seconds of time intervals.
    • Do not touch the tip of the Soldering iron directly onto the battery. Only apply melted solder alloy onto the battery contact tab.
    • Ensure that the positive and negative electrodes are correctly identified and now place the new batteries onto the battery holder.
    • Apply Soldering paste on the battery contact tab and then melt solder alloy on to the tip of the soldering iron and touch the tip of the soldering iron to one of the 4 specified battery contact tab. Repeat this same step for the other 3 battery contact tabs. Apply some more soldering iron alloy if the batteries do not feel rigid on the holder.
  9. Braun BT3240 Electric Trimmer Battery Replacement: étape 9, image 1 de 2 Braun BT3240 Electric Trimmer Battery Replacement: étape 9, image 2 de 2
    • Once the solder on each side has dried out and in cool temperature, you can reassemble the parts and test the trimmer’s functionality.
    • To check if the trimmer works perfectly, you need to notice the head of the trimmer. The head of the trimmer should be rotating clockwise when you press the power button.
Harsh Mishra
Membre depuis le 01/17/23
180 Réputation
1 tutoriel rédigé
Équipe
York University, Team O-8, Woodhouse Winter 2023 Membre de l'équipe York University, Team O-8, Woodhouse Winter 2023
YORK-WOODHOUSE-W23SOG8
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 27
Total : 505
