Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Braun M1000 gearbox Replacement
Ce dont vous avez besoin
  1. Braun M1000 gearbox Replacement, Open the plastic enclosure: étape 1, image 1 de 2 Braun M1000 gearbox Replacement, Open the plastic enclosure: étape 1, image 2 de 2
    • Put the mixer in a vise as shown in picture and gently press it. You can use plastic vise jaws to avoid scratching the case.
    • Increase the vise pressure and pull the handle until it pops out. It is important to apply the correct pressure to release the plastic hooks.
    Demander à FixBot
    Ajouter un commentaire
  2. Braun M1000 gearbox Replacement, Open the gearbox: étape 2, image 1 de 3 Braun M1000 gearbox Replacement, Open the gearbox: étape 2, image 2 de 3 Braun M1000 gearbox Replacement, Open the gearbox: étape 2, image 3 de 3
    • Unlock the gearbox cover using a T15 torx key
    • Remove the gearbox cover by pressing it as show in the picture
    Demander à FixBot
  3. Braun M1000 gearbox Replacement: étape 3, image 1 de 3 Braun M1000 gearbox Replacement: étape 3, image 2 de 3 Braun M1000 gearbox Replacement: étape 3, image 3 de 3
    • Pull the central gear to remove it from the crankshaft. In the picture you can see the crack in the gear that was causing excess noise.
    • Replace the gears with the spare parts. The central gear needs to be inserted with some force on the crankshaft. A small hammer can be used to get the central gear in place.
    Demander à FixBot
  4. Braun M1000 gearbox Replacement: étape 4, image 1 de 1
    • Put the gearbox cover back in place with the torx screws.
    • Push the plastic enclosure back in place. Press gently until it clicks in place.
    Demander à FixBot
Ligne d'arrivée
Luca V
Membre depuis le 03/30/17
221 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 52
Total : 1,747
