Aller au contenu principal
Braun Series 7 790cc-7 Battery Replacement
Ce dont vous avez besoin
  1. Braun Series 7 790cc-7 Battery Replacement, Battery: étape 1, image 1 de 2 Braun Series 7 790cc-7 Battery Replacement, Battery: étape 1, image 2 de 2
    • Use a spudger to remove the rubber piece on the back of the razor.
  2. Braun Series 7 790cc-7 Battery Replacement: étape 2, image 1 de 1
    • Use a Torx T8 to remove (4) 10 mm screws from housing.
  3. Braun Series 7 790cc-7 Battery Replacement: étape 3, image 1 de 2 Braun Series 7 790cc-7 Battery Replacement: étape 3, image 2 de 2
    • Remove the rear cover from the device.
  4. Braun Series 7 790cc-7 Battery Replacement: étape 4, image 1 de 1
    • Remove the battery from the holster inside the device.
  5. Braun Series 7 790cc-7 Battery Replacement: étape 5, image 1 de 1
    • Replace the battery with a new 1300 mAh Sanyo (UR18500Y) battery.
    • Be sure to insert the battery the correct way.
27 autres ont terminé cette réparation.
Alex Speer
Membre depuis le 11/07/17
763 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S3-G6, Harley Fall 2017 Membre de l'équipe IUPUI, Team S3-G6, Harley Fall 2017
IUPUI-HARLEY-F17S3G6
3 membres
5 tutoriels rédigés
27 commentaires
Any idea on how to remove/replace the drive unit? I bought a new one but the plastic backing is extremely hard to get off.
Chris - Réponse
Thank you for the awesome tutorial Alex!
I just wanted to comment that a small flat-head screw driver can be used to remove the 4 screws (under the rubber handle piece) if you don’t have a Torx tool. The screws each have 1 small slot across the head and if you’re careful you can remove and re-install them without too much trouble.
Thanks again for helping to save me a lot of trouble with this Alex… and avoid having to buy a new electric razor!
-jb-
arcticassault - Réponse
How do you reset the battery life indicator on the shaver after replacement?
jclemis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 30
7 derniers jours : 150
30 derniers jours : 687
Total : 54,677
