Aller au contenu principal
Braun Series 7 790cc-7 Charging Base Wire Harness Replacement
Ce dont vous avez besoin
  1. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement, Charging base wire harness: étape 1, image 1 de 1
    • Remove the cleaner cartridge from the charging base.
  2. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: étape 2, image 1 de 3 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: étape 2, image 2 de 3 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: étape 2, image 3 de 3
    • Depress the 4 tabs while lightly pulling the cover from the base.
    • Next, depress the 2 molded tabs while still pulling the cover from the base.
  3. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: étape 3, image 1 de 1
    • Press inward on the side charging port while pulling cover from the base to separate.
  4. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: étape 4, image 1 de 2 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: étape 4, image 2 de 2
    • Remove side charging port by prying tabs outward and rotating port upward.
  5. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: étape 5, image 1 de 2 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: étape 5, image 2 de 2
    • Remove charging terminals by inserting a spudger from bottom the and sliding terminals up.
  6. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: étape 6, image 1 de 2 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: étape 6, image 2 de 2
    • Remove solder from circuit board and remove charging harness.
Ian Hayes
Membre depuis le 11/07/17
216 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G6, Harley Fall 2017 Membre de l'équipe IUPUI, Team S3-G6, Harley Fall 2017
IUPUI-HARLEY-F17S3G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 18
Total : 1,100
