Aller au contenu principal
Braun Shaver Model 7680 Battery Replacement
Ce dont vous avez besoin
  1. Braun Shaver Model 7680 Battery Replacement, Battery: étape 1, image 1 de 1
    • Soldering is required to install this battery one or two batteries may be required verify how many you need before you order
  2. Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: étape 2, image 1 de 2 Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: étape 2, image 2 de 2
    • First pry the left side of the cover off, then pry the right side of the cover off before removing. Trying to pry the cover off from only one side will result in breaking the plastic tabs.
  3. Braun Shaver Model 7680 Battery Replacement, Remove side covers: étape 3, image 1 de 1
    • Pull the side covers off from the bottom, they hinge from the top and will come off freely once you rotate them up and away from the body starting at the bottom.
  4. Braun Shaver Model 7680 Battery Replacement, Remove screws on back: étape 4, image 1 de 2 Braun Shaver Model 7680 Battery Replacement, Remove screws on back: étape 4, image 2 de 2
    • You will need a T9 hex screw driver.
    • R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm
    • Replacing the batteries will not always repair the shaver, the circuit board may be bad, if the indicator lights on the circuit board do not light up when plugged in the circuit board is most likely bad, you should replace the entire circuit board and battery assembly.
19 autres ont terminé cette réparation.
mayer
Membre depuis le 01/04/10
686 030 Réputation
12 tutoriels rédigés
Équipe
MacHale Enterprises Membre de l'équipe MacHale Enterprises
Business
1 membre
19 tutoriels rédigés
8 commentaires
Great tutorial. It was all I needed, since I wasn't sure how to get the case open. Thanks!
mikebailey - Réponse
Thanks for the tutorial! Mine had intermittent problem with the on/off switch and I was googling how to open the case. Easy and simple, bets razor I’ve had and not willing to change :D
Tero Kortetmäki - Réponse
Thanks for the tutorial… but it is a T8 Torx at least in the Model 7570. I just had to take out the recharchable batteries to get mine working properly again.
A Krueger - Réponse
Danke für die übersichtliche Anleitung, hat mir gut geholfen. Die wichtige Frage ist immer:
Wie geht ‘s Gehäuse auf. ?
Garofalo - Réponse
Thanks for the guide! Without knowing how to open the case, replacing the battery would have been a lost cause. In my case the batteries were tired. After replacing and recharging them the razor sounds young again and full of pep.
Stephen Spratley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 100
Total : 21,814
