Aller au contenu principal
Braun hld6 Disassembly
Ce dont vous avez besoin
  1. Braun hld6 Disassembly, Braun hld6 Disassembly: étape 1, image 1 de 1
    • Make sure the hairdryer is not plugged in!
    • Take out the two 32.3 mm Phillips #1 screws from the outside.
    • Take out the one 6.0 mm Phillips #1 screw.
  2. Braun hld6 Disassembly: étape 2, image 1 de 2 Braun hld6 Disassembly: étape 2, image 2 de 2
    • Pry apart the two main bodies.
  3. Braun hld6 Disassembly: étape 3, image 1 de 1
    • Take out the last outside screw, a 6.0 mm PH #1, to remove the grid.
  4. Braun hld6 Disassembly: étape 4, image 1 de 2 Braun hld6 Disassembly: étape 4, image 2 de 2
    • Take out the 14.6 mm Flathead screws that hold the power cord in place.
    • Take out the 18.2 mm Flathead screws that hold the buttons in place.
    • Take out the 27.1 mm Flathead screws that keep the motor in place.
  5. Braun hld6 Disassembly: étape 5, image 1 de 3 Braun hld6 Disassembly: étape 5, image 2 de 3 Braun hld6 Disassembly: étape 5, image 3 de 3
    • Take out the interior.
  6. Braun hld6 Disassembly: étape 6, image 1 de 2 Braun hld6 Disassembly: étape 6, image 2 de 2
    • Loosen the 2 flathead screws in the terminal block closest to the power cord.
    • Pull out the power cord.
  7. Braun hld6 Disassembly: étape 7, image 1 de 2 Braun hld6 Disassembly: étape 7, image 2 de 2
    • Loosen the flathead screws and remove the wires from the button holder. Remove the button holders. When you unscrew the wire opposite to where the yellow wire is connected, you can slide the button off of the middle wire connected to the motor.
  8. Braun hld6 Disassembly: étape 8, image 1 de 1
    • Lastly, remove the yellow wire.
  9. Braun hld6 Disassembly: étape 9, image 1 de 1
    • Take out the diode.
  10. Braun hld6 Disassembly: étape 10, image 1 de 2 Braun hld6 Disassembly: étape 10, image 2 de 2
    • Remove the flathead screws from the back of the motor.
    • To take apart the remaining parts, desoldering is required.
Roisin
Membre depuis le 03/07/18
181 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 331
